Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › LoadLibrary failed with error 87 › Reply To: LoadLibrary failed with error 87
February 4, 2021 at 1:21 pm
Array Are you running on a Remote Desktop and that machine has an AMD graphics card?nAre you able to open an Administrator command prompt and then try running the ConfigureThisMachine.exe separately after the install? Modify the path for the version you are trying to run.nC:\Program Files\AnsysEM\AnsysEM20.1\Win64\config\ConfigureThisMachinenn
