Ansys Learning Forum Forums Discuss Simulation General Mechanical How can I plot and display contours for average temperature only instead of max. & min. temperature? Reply To: How can I plot and display contours for average temperature only instead of max. & min. temperature?
Whiteney1991
Thank you. Yes I did play the animation. nHowever, looking at the Tabular data in the previous attachment, the last column shows the Average temperature. I was however wondering, is there a way I can make the plot (on the left of the Tabular Data) to show the plot of average temperature vs time and exclude those of maximum and minimum temperatures vs time? nAlso, looking at the temperature contours in the attached image, is it possible to display the average temperature at a particular time instead of the max and min at a particular time? For example, attached image shows the max and min at 7.44s. Are there settings that I need for it show the average temperature only?nThanksnn
