Ansys Learning Forum Forums Discuss Simulation Fluids No Active Application error ,Cortex Recieved a Fatal Signal Reply To: No Active Application error ,Cortex Recieved a Fatal Signal
Karthik Remella
Administrator
Are you trying to read a new mesh file into an existing case file? If so, I'd suggest that you start setting up the case from scratch. Read the mesh file as the starting point and start setting-up your case from the beginning and see if you get the same error. Please let us know your findings.nKarthikn
