Ansys Learning Forum › Forums › Discuss Simulation › Fluids › I want to know how can I get particle history data as Ensight without separated file › Reply To: I want to know how can I get particle history data as Ensight without separated file
DrAmine
That option should be the same as the automatic export of EnSight during calculation. So Unchecking should be consistent.You wrote this is not working:which version you are using? Can you reproduce on simple file?n
