Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem in ANSYS Static structural Simulation › Reply To: Problem in ANSYS Static structural Simulation
February 2, 2021 at 7:50 pm
nI tried your google drive but you have moved the file to the trash so I could not download it.nSome suggestions to speed up computation time.nUse Beam elements for the braidnUse Shell element for the tubenYou can use a Pressure load to inflate the rubber tube, there is no need to model the air.nn
