Ansys Learning Forum Forums Installation and Licensing Ansys Products Job was not run on the cluster. Check the cluster logs and check if the cluster is configured propr Reply To: Job was not run on the cluster. Check the cluster logs and check if the cluster is configured propr
yskalencat
Log file detailsn2021-02-02 12:55:18 [INFO] UserProxy started as hessamedinn on loginn2021-02-02 12:55:18 [DEBUG] Running on Monon2021-02-02 12:55:18 [INFO] UserProxy startedn2021-02-02 12:55:18 [INFO] Version 19.4.420.0 [Monday, 08 April 2019 10:09]n2021-02-02 12:55:18 [INFO] User: hessamedi2021-02-02 12:55:18 [INFO] PID: 19865n2021-02-02 12:55:18 [INFO] Proxy Idle Timeout: 0:10:00n2021-02-02 12:55:18 [INFO] Port: 40308n2021-02-02 12:55:18 [INFO] Port: 40308n2021-02-02 12:55:18 [INFO] Created MemoryMappedFile named USERPROXY194_HESSAMEDINN_HESSAMEDINNn2021-02-02 12:55:53 [DEBUG] TransferServer2 created.n2021-02-02 12:55:53 [DEBUG] TransferServer2 disposed.n2021-02-02 12:55:54 [DEBUG] AssemblyResolver: Loading /workarea/athenasoftwares/ansys2019R2/ansys_inc/v194/RSM/bin/FrameworkDependencies/Ans.Rsm.Localization.dlln2021-02-02 12:55:54 [DEBUG] AssemblyResolver: Loading /workarea/athenasoftwares/ansys2019R2/ansys_inc/v194/RSM/bin/FrameworkDependencies/netstandard.dlln2021-02-02 12:56:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 12:57:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 12:58:14 [DEBUG] TransferServer2 created.n2021-02-02 12:58:14 [DEBUG] TransferServer2 disposed.n2021-02-02 12:58:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 12:59:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:00:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:01:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:01:38 [DEBUG] TransferServer2 created.n2021-02-02 13:01:38 [DEBUG] TransferServer2 disposed.n2021-02-02 13:02:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:03:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:04:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:05:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:06:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:07:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:08:07 [DEBUG] TransferServer2 created.n2021-02-02 13:08:07 [DEBUG] TransferServer2 disposed.n2021-02-02 13:08:18 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:09:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:10:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:11:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:12:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:13:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:14:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:15:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:16:19 [DEBUG] ProcessActivityTracker shows activity.n2021-02-02 13:17:19 [DEBUG] ProcessActivityTracker shows activity.n
