Ansys Learning Forum › Forums › Discuss Simulation › Fluids › how can i get the values of heat gained by a certain surface and air in a box subjected to sun › Reply To: how can i get the values of heat gained by a certain surface and air in a box subjected to sun
February 2, 2021 at 12:40 pm
Use surface and volume reports. These need to be set up and monitored during the solution. The data file for Fluent contains instantaneous values and not the solution history. n
