Ansys Learning Forum › Forums › Discuss Simulation › Fluids › 999999: mpt_accept: error: accept failed: No error › Reply To: 999999: mpt_accept: error: accept failed: No error
Keyur Kanade
This error may come in due to many reasons. nFirst check your UDF. nPlease check if you can run it with double precision. nCheck your mesh quality. The min orthogonal quality should be more than 0.1. nYou have 2.6M cells and 8GB RAM. Can you please check if you can reduce mesh size? nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
