Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Thickness over the surface with VoF model › Reply To: Thickness over the surface with VoF model
February 2, 2021 at 12:32 pm
I tend to create an iso-surface of water volume fraction and then report the x, y or z position on the surface. Assuming the wall has a constant position you can then subtract that from the free surface to get a depth. I use CFFs for that, and Expressions will allow this if they don't already (I've lost track of what is current, in testing and in development with Expressions as functionality is being added in the test builds almost weekly). n
