Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Negative temperature results after conjugate heat-transfer › Reply To: Negative temperature results after conjugate heat-transfer
Fluent should solve for 500k elements. Just remember that some models may create virtual cells so you may gain a few when switching to Fluent. nHave a look at the adaption registers, iso surfaces and volume reports. n
