Ansys Learning Forum Forums Discuss Simulation General Mechanical Mechanical exclude geometry from report Reply To: Mechanical exclude geometry from report
grotstein
Dear Aniket,nthank you for replying. I was not aware of the ClassToString.xml file, so your comment helped.nHowever, adding the ID to only excluded the Geometry from the table of contents. Adding it to also excluded it from the report, but, unfourtunately, the script still reads the data, it just doesn't put it in the report. So my problem was not solved. I guess the only way to solve it is to change/ improve the script in Generator.js.n
