Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Unable to temperature variations in Ansys as a result of loses from Maxwell › Reply To: Unable to temperature variations in Ansys as a result of loses from Maxwell
karthik.remella
Administrator
Hello,nOnce you export the load from Maxwell, what does it look like when you read this into Steady-State Thermal? Can you plot just the 'Imported Heat Generation' Load and post the contour here? Do these values compare with what you are seeing in Maxwell?nKarthiknn
