Ansys Learning Forum Forums Discuss Simulation General Mechanical GPU Acceleration Not Doing Much (2x Quadro GP100)? Reply To: GPU Acceleration Not Doing Much (2x Quadro GP100)?
peteroznewman
nIf you ever get into CFD, then you will find the GPUs provide a significant benefit.nAlso, if you use the Discovery products, those do all the calculations on GPUs to provide real-time results that update as you drag geometry or forces around on the screen.n
