Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › What is the most effective way to replicate the same structural components to create a building? › Reply To: What is the most effective way to replicate the same structural components to create a building?
January 16, 2021 at 11:23 am
Thank you nYour assistance has helped me resolve this problem, and i have a nice clean geometry to import into mechanical. This has eliminated a host of problems that i was having in mechanical such as elements loosing properties, issues with nodes in surfaces etc etc.nnI have had to reduce the coincidence tolerance to 0.08m, but i consider that this is necessary as the gap between adjacent surfaces is 0.1m. A screen shot of this solution is provided below to close out this thread.n
nMany Thanks.nnPS. The slab is formed with a rectangle in sketch and its edges are used for the beams.n
