Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Acoustophoresis for particle separation in fluid. › Reply To: Acoustophoresis for particle separation in fluid.
January 13, 2021 at 11:56 am
Moving to fluids, nYou won't find that specific model in the code. However, if you take a step back and look at what the actual transport mechanism is it should be possible. Ie sound is pressure waves which can add a force to an object if it's present. n
