Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to apply a pressure load which varies with respect to radius of annulus in workbench? › Reply To: How to apply a pressure load which varies with respect to radius of annulus in workbench?
January 2, 2021 at 4:16 pm
Thank you for a completely described question! You can get what you want without resorting to APDL.n#1. Make a Cylindrical Coordinate Systemn
#2. Use Excel to make a table of Pressure vs Radius. In the example below, I put a P in front of your equation.n
#3. Create a Pressure load using Tabular Data. Set the Independent Variable to X instead of Time. Use the Cylindrical Coordinate System and copy/paste the Excel cells into the Tabular Data field. Just pick the first cell and Paste.n
Static Structural is the right place to build this model. Transient Structural is useful if accelerations are high enough to generate significant inertia forces.n
