Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › LS-Run License setting issues › Reply To: LS-Run License setting issues
November 16, 2020 at 9:27 pm
susun
Hello MangeshANSYS,nnI could check that my license server setup under ANSLIC ADMIN is correct and I could run Ansys Mechanical, however, still getting problem with LS-Run.nTherefore, can I ask you where I can find the environment variable LSTC_LICENSE=ANSYS? nMaybe I should check it preferentially.nnThank you.n
