Ansys Learning Forum Forums Discuss Simulation General Mechanical The solver engine was unable to converge on a solution for the nonlinear problem as constrained. Reply To: The solver engine was unable to converge on a solution for the nonlinear problem as constrained.
Gary Stofan
Hi Beatriz. The last 3 warnings are important. It appears you have multiple boundary conditions or contacts or joints applied the same entities. This will cause conflicts and the conditions will not be applied correctly. A suggestion would be to see if your model can solve with just fixed supports and gravity, then add conditions from there. n
