Ansys Learning Forum Forums Discuss Simulation Materials Hyperelastic Material Not Deforming Much Reply To: Hyperelastic Material Not Deforming Much
peteroznewman
nWhat angle is reported when you set the Result Selection to the Z axis. That is the axis about which the deformation angle would be largest. It looks like rotation about the Y axis should be close to zero.n
