Ansys Learning Forum Forums Discuss Simulation LS Dyna Why build the SPH layer at the bottom? Reply To: Why build the SPH layer at the bottom?
Miner
Hi all, I have a new issue in this simulation. After the water droped down, there are some particles move upwards along the left rigidwall. It is like those particles adhere to the wall. I have tried to reduce the gap between wall and water, but doesn't work. Could you help me to resolve this?https://us.v-cdn.net/6032193/uploads/AQFXOQNSY04K/image.png/forum/discussion/comment/96759#Comment_96759
The rigidwall must align the part surface. When change the particle spacing, small gap may generated between the rigidwall and part surface, thus the contact between rigidwall and part produced weird results. If particle spacing is changed, the rigidwall must be updated.n
