Ansys Learning Forum Forums Discuss Simulation General Mechanical Dependency of Strain rate to type of analysis (Static ,Quasi static and Dynamic explicit) Reply To: Dependency of Strain rate to type of analysis (Static ,Quasi static and Dynamic explicit)
Mansoureh
Hi @sdeogeka,nThank you for your time to explain for me. Definitely it was useful for me.nWhat about using Autodyn? If I the strain rate be in the range of for example 2 mm/s, should I use Autodyn for solving?nthanks againn
