Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to introduce the good thermal conductivities of a tubular composite structure with Ansys ACP ? › Reply To: How to introduce the good thermal conductivities of a tubular composite structure with Ansys ACP ?
September 19, 2020 at 6:36 am
Hello sharvey,nThank you so much for your response. Material Designer is really interesting as a modeling tool.nI m lost because I don't understand why in my results obtained for the analysis of a composite pipe, the strains along the radius (Y and Z axis) are different while in the Engineering data, the limits of tensile strain along y and z axis are the same. (the pressure is applied over the entire circumference. )nI tried the same problem in cylindrical coordinates but I got the same result.nDo you have any explanation for my problem ?n
n
n
