Ansys Learning Forum Forums Discuss Simulation Fluids No domains have been defined Reply To: No domains have been defined
Feraz
Hello,nnI take this messages as base, because I have the same problem. But I have a 3D mesh. In fact, the mesh is the one in the Workshop 1-Mixing Tee (ANSYS CFX Getting Started).nI thought it could be because the versions (I'm using 2019r3 and the model is made in 2019r2), but I have the same problem if I import the step and I mesh the geometry in 2019r3.nnDo you have an idea about which could be the problem?.Thank you very much in advance,nFernandonnn
