Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Adding multiple load cases in one mechanical model for static structure › Reply To: Adding multiple load cases in one mechanical model for static structure
September 8, 2020 at 6:18 pm
In Workbench, the first Static Structural block, the Model cell A4 is where the meshing and material assignment is done, then drag and drop multiple Static Structural blocks onto the Model cell A4, B4, C4 for each additional load case.n
In Workbench, you can drag and drop the Fixed Support from the first analysis onto each additional analysis. Then each analysis can have its own unique force.n
n
n
