Ansys Learning Forum Forums Discuss Simulation Fluids The ‘lumped-capacitance’ model of transient heat transfer Reply To: The ‘lumped-capacitance’ model of transient heat transfer
Karthik Remella
Administrator
Hello @kkanade , you can use Biot number to quickly check if the lumped-capacitance assumption is valid or not for a particular problem. Biot Number is the ratio of conduction resistance to convective resistance. It is mathematically defined as:
Bi = h*L / k
where,
h = heat transfer coefficient [W/(m^2-K)]
L = conduction length scale [m],
k = thermal conductivity [W/(m-K)]
For Smaller values of Biot number the heat conduction inside the body is faster than the heat convection at its outer surfaces, and therefore the temperature gradients inside the body can be neglected. Bi in the range of <0.1 typically leads to an error of <5% if lumped-capacitance model is used.
