Ansys Learning Forum Forums Discuss Simulation General Mechanical Not Enough Memory Error? Reply To: Not Enough Memory Error?
Autonewbie
Hi Peter,
I restart the workstation (I did not change any memory setting) but it is issue with the warning below. However, I changed the model smaller with spring, it can run. But I have bigger model (3 - 4 times) for transient and random analyses also no problem except this time with spring.
 *** WARNING ***                         CP =       8.641   TIME= 22:14:51
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** WARNING ***                         CP =      10.641   TIME= 22:14:51
 Material number 7 (used by element 287758) should normally have at
 least one MP or one TB type command associated with it.  Output of
 energy by material may not be available.
 *** WARNING ***                         CP =      18.344   TIME= 22:14:54
 Too many nodes 10720 are included in the force-distributed-surface
 constraint identified by real constant set 5.  This may greatly affect
 solver performance due to large wave fronts and memory consumption.
 Also check results carefully and consider solving with a different
 unit system.
