Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Floating Point Error: Solidificaiton/Melting with PCM 2D › Reply To: Floating Point Error: Solidificaiton/Melting with PCM 2D
June 23, 2020 at 1:21 am
Dear Rahul,
I have just attached a picture of the result of the run. This is a contour of total temp. After confirming that I indeed patched for 273.5k after 3 iterations i get the failure and the output shows the inside temp at 1k with 5000k scattered around. I have never seen results like this, making me believe this is a small error I'm just overlooking.
