Ansys Learning Forum Forums Discuss Simulation General Mechanical Solver Pivot Error_2 Reply To: Solver Pivot Error_2
nav2en
A - Heat flow; B - Convection
I applied all the way possible but it brings up the same error. Referring to the above picture, the blue area where heat flows, and the yellow area where the convection happens, I did not consider conduction and radiation as of now. It still brings up the same error.
Even though the setup does not represent the actual brake cool off, it has to yield me bad results. But here the simulation doesn't run. I might be wrong on this with Ansys but Solidworks runs it.
