Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Meshing Issue with Through Hole Close to Perpendicular Blind Hole › Reply To: Meshing Issue with Through Hole Close to Perpendicular Blind Hole
peteroznewman
I recommend you create a plane on the orange face, then Split all bodies with that plane.
In ANSYS 2019 R3, I used the Workbench tab and clicked on the Share button and I think the Shared Topology is going to let the mesh be connected.
