Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › visualization of 2D becomes 3D after optimization and extended density distribution › Reply To: visualization of 2D becomes 3D after optimization and extended density distribution
February 24, 2020 at 3:35 pm
An MBB Beam is a simply supported beam of which only half is modelled since it is symmetrical. See figure 6 in this link:Â https://www.researchgate.net/publication/330853881_Topology_Optimization_Under_Uncertainty_by_Using_the_New_Collocation_Method
Anyhow, I found how to model the densities, I did it with a user defined result with expression ETOPO.
I will try to do as you said in SpaceClaim
thanks
