Ansys Learning Forum Forums Discuss Simulation General Mechanical Define gap with contact element CONTA178 Reply To: Define gap with contact element CONTA178
peteroznewman
So build a 2 beam, 4 node model with a gap between the end points the beams as I did in this post, and try each element to see what works for you.
