Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Tips on meshing a thin body › Reply To: Tips on meshing a thin body
cbhavsar
Here are two tips on meshing thin bodies: 1 Check the defeaturing size. Reduce the defeaturing size below the thin dimensions to capture the thin features properly. 2. Check mesh size. If it is too coarse on the thin feature, use fine sizing.
