Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Direct electro-thermo mechnical model › Reply To: Direct electro-thermo mechnical model
Dear Stefan,
The aim of the model is to simulate hot pressing procedure by taking advantage of the electric current. It should have strong coupling between quasi-static electric conduction, transient thermal and static structural. All three physics should solve simultaneously because the density and geometry of the sample is changing by temperature rising from room temperature to 1100 C. I just need a model in workbench that can solve all three physics at the same time, but not by connecting the wires between the physics.I am also familiar with APDL commands a little, but not that much. I would be appreciated if you could give me some hints to solve this problem.
Sincerely,
Bijan
