Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › SIF evaluation in Ansys Workbench › Reply To: SIF evaluation in Ansys Workbench
October 4, 2017 at 12:56 am
Workbench uses the Contour Integration approach (CINT). Contours are numbered radially outward, and there's no limit on the number of contours.
Both an Interaction Integral Method and Displacement Extrapolation Method are available in Mechanical APDL (see here) and you can insert a CINT,TYPE, SIFS based command snippet into your Workbench Mechanical simulation to specify the method directly if you don't wish to use the ANSYS Workbenches automated crack procedure. etc.
