Ansys Learning Forum Forums Discuss Simulation General Mechanical Seismic analysis of a water filled tank Reply To: Seismic analysis of a water filled tank
pgl
This depends on how important the water sloshing is to your application: If the tank is completely full, you could assume the water is a solid. That might be an oversimplification. You could also assume that the tank is a rigid body. For best results you'll need to perform a two way fluid-structural interaction simulation. That will capture the movement of the fluid and the deformation of the tank.There's quite a few published tutorials example on YouTube, for example, here's an AIM FSI tutorial to get you started:
https://youtu.be/Vdvlg5yzVDc?list=PL0lZXwHtV6OkiLQmjjcgoydHUTiIvmV0N:
Also, here's two videos of a seismic simulation of fluid filled tanks:
https://www.youtube.com/watch?v=hZ_FUn2q4y0
https://www.youtube.com/watch?v=2WsnW9J1qHU
