Ansys Learning Forum Forums Discuss Simulation Fluids Employ user chemistry in Chemkin Reply To: Employ user chemistry in Chemkin
Chitral.Naik
User rate routines can be programmed by editing the template subroutines provided in /reaction/chemkinpro.win64/user_routines/cklib_user_routines.f Fortran code.
- You can use CKUPROG to provide reaction rate of progress for reaction for a specific reaction, or CKUPROD to provide rates-of-production of all the species.
- Instructions to recompile and link the API code is given in the Chemkin-Pro API Manual - Section 2.1.
- Once the user code is linked successfully, you will need to add the corresponding keyword USRPROG or USRPROD in the reaction mechanism file. Example of a gas phase mechanism using USRPROD is show here. This mechanism will use the custom rates-of-production in any Chemkin simulation.
ELEMENTS
H O C N
END
SPECIES
CH4 CH3 CH2O CO2 CO H2 H O2 O OH HO2 H2O2 H2O C2H2 C2H4 C2H6
NO HCN NO2 N2
END
REACTIONS USRPROD
END
