April 24, 2021 at 11:02 am
moustafa
SubscriberHello,I am currently working on a complex coil geometry in a Magnetostatic Simulation. The geometry with the desired current directions is depicted in the image. In the circle segments, the current shall follow the geometry.nMy question now is how to implement the different current directions (one solid) in the simulation.nI appreciate your help.Kind regards, H. Moustafan -
May 12, 2021 at 6:30 pm
dlooman
Ansys EmployeeIt's not possible to accurately specify current density for an arbitrary shape like the one shown. Instead, a current conduction analysis should be done. The coil will need to be split somewhere so that a ground (zero voltage) and the current can be specified at the cut ends. After the current conduction analysis, ldread can be used to read the current density into the magnetic analysis which will have the same mesh plus air elements.
June 9, 2021 at 12:30 pm
moustafa
SubscriberThank you for your help. It worked.
- The topic ‘How to define current direction for a complex coil (Magnetostatic)?’ is closed to new replies.
Ansys Innovation Space
1414
1241
1118
1015
