TAGGED: ansys-simplorer, cosimulation, maxwell, maxwell-simulations
April 23, 2021 at 2:41 am
ranjanpal999
SubscriberHi,nI wish to build a vector controlled VFD in ANSYS Simplorer and make it drive a 3-Ph PMSM motor modeled in MAXWELL.nI could find links to some research papers where this has been achieved:nhttps://iopscience.iop.org/article/10.1088/1757-899X/872/1/012047/pdfnhttps://core.ac.uk/download/pdf/188803398.pdfnI have my 3-Ph PMSM motor model ready in MAXWELL.nHowever, I am still trying to learn how to model a VFD in Simplorer and co-simulate that with MAXWELL.nSince I am just a beginner in this area, can somebody please let me know of some documentation or links wherein we can learn step-by-step procedure to model a VFD and and its co-simulation with MAXWELL ?n -
April 28, 2021 at 2:18 pm
May 14, 2021 at 9:43 am
- The topic ‘Co-simulate ANSYS Simplorer and ANSYS MAXWELL for 3-Ph PMSM motor’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1338
1188
