March 29, 2021 at 4:53 pmibopaul SubscriberHello! I'm trying to compare the performance of AMG solver.nI found turn off the AMG solver by setting Max Coarse Levels to '0'.nHowever, after I turn of the AMG solver, which linear equation solver I use?nstill, after i turn off the AMG, there are pre relaxation and post relaxation blanks and inner cycle blanks. Also there only two smoother types (ILU, Symmetry Gauss-Seidel). nIf I turn off the AMG, AMG-related blanks (pre-relaxation, post relaxation & inner cycle) are just ignored?nIs there any way to use one Gauss-Seidel iteration method on flow solver? (to compare AMG acceleration performance)nMy simulation is steady & density based.nnThank you.n
March 30, 2021 at 4:39 am
March 30, 2021 at 5:31 amAmine Ben Hadj Ali Ansys EmployeeWhy?n
March 30, 2021 at 6:32 amibopaul SubscriberI wanted to know the speed difference as to whether or not to use AMG.nIs it impossible to compare the calculation speed?nThank you.n
March 30, 2021 at 8:30 amAmine Ben Hadj Ali Ansys EmployeeWith AMG you will always have quicker runs. It is practically impossible to have reasonable run times without using Multigrid Methods. n
Viewing 4 reply threads
- The topic ‘Is there any way not to use the AMG solver?’ is closed to new replies.
- affinity not set
                        1487
                        1363
                        1194
 You are navigating away from the AIS Discovery experience
