March 12, 2021 at 12:17 pm
Rajan_Mistry
SubscriberI am simulating a microwave resonator in HFSS using the driven modal solver with a fast frequency sweep. I have used the field calculator to calculate the mean electric field in a block of air just above the resonator. But this only calculates for a single frequency in the sweep. How can apply this to all frequencies in the sweep to export a plot of mean E vs frequency ?n -
March 12, 2021 at 4:20 pm
Praneeth
Ansys EmployeenAre you trying to evaluate the average field over the defined volume or you want average field over the frequency range?nKindly confirm.nBest Regards,n -
March 12, 2021 at 4:31 pm
Rajan_Mistry
SubscriberThanks for your reply.nI want to average the field over the defined volume (which I have done using the field calculator) and then plot this average field against frequency.n -
March 12, 2021 at 5:22 pm
Praneeth
Ansys EmployeeHi,nDid you try assigning an output variable for the desired quantity? Kindly look into HFSS Help document regarding the definition of output variable.nAll the very best.nBest Regards,n -
March 16, 2021 at 12:37 pm
Rajan_Mistry
SubscriberThat works now, thank younn
Viewing 4 reply threads
- The topic ‘Export mean Electric field for all frequencies’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1241
1118
1015
