March 10, 2021 at 8:31 pm
Koontzja
SubscriberHello,
I am working with a user at my University who is having issues getting Ansys 2021 R1Toolbox to work properly and show the Analysis Systems items he needs. We are able to see the Analysis Systems components the user needs within Toolbox Customization, but when we check the item we need within Toolbox Customization, it does not show up under the Toolbox on the left-hand side (See attached image). The user is able to see and use the Analysis Systems tools he needs in versions 19.2 and 2020 but not the 2021 version of the software. I have verified that our Licensing Manager is up to date, and on the 2021 version, and have tried multiple machines and had no different results in installing the software.
I have seen some reports of previous versions of Ansys on the same machine causing issues, the image you are seeing below is from a machine that has had no other versions of Ansys installed. If any additional information is needed, I'd be happy to provide any specifics. Any helps towards solving this issue is much appreciated.
Thank you!
March 11, 2021 at 3:03 pmANSYS_MMadore
Forum ModeratorArray Reached out directly. Thank you.
March 18, 2021 at 1:30 pmnhelmy
SubscriberI had the same problem with ANSYS 2021 R1, the student version. I had to uninstall and reinstall. Is there any other solution, so I don't have to reinstall it again?
Thanks
March 20, 2021 at 1:57 pmcrysise
SubscriberArray i'm same problem in korea plz solve this problem
March 20, 2021 at 1:59 pmcrysise
SubscriberArray did you work your student ver after re-install?, why i can't work my toolbox,
March 22, 2021 at 10:52 amANSYS_MMadore
Forum ModeratorArray There could be several causes, have you reviewed the forum for additional threads on this topic?
July 12, 2021 at 9:36 amjordi.marce.nogue
Subscriber.mmadore I am reading the other threads but all of them are regarding the student version. I am using the academic version from my university and I have the same problem in ansys 2021. I have no problems with 2020 and 2019
.July 13, 2021 at 5:16 pmJuly 14, 2021 at 12:00 amViewing 8 reply threads- The topic ‘Ansys 2021 – Analysis Systems Tools not showing up in the Toolbox’ is closed to new replies.
3767
1333
1173
1090
1014
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
