March 8, 2021 at 9:16 am
abdalla
SubscriberDear StaffnPlease tell me :nCan Ansys Workbench consider the PINCHING effect during modeling concrete shear wall under CYCLIC loading?n -
March 9, 2021 at 6:22 pm
Kai
Ansys EmployeeHi, pinching effect is not considered in general purpose FEA software such as Ansys.n -
March 10, 2021 at 7:50 am
ErKo
Ansys EmployeeHinnAlso our recommended material models for concrete (Menetrey-Willam, or DP, ...) are missing in their formulation important complex effects (e.g., unilateral effects) that can be present and that can be important for cyclic loading. Just something to be aware of alsonnErikn -
March 20, 2021 at 8:22 am
abdalla
SubscriberOK, to get accurate results and consdier pinching effect of cyclic loading, I ask you can the user insert the Mandery concrete model as APDL commands into workbench?nThanksn -
abdalla
Subscribern -
August 22, 2022 at 10:22 pm
hossam.moustafa4655
SubscriberDid any one overcame that problem ? If Ansys can not consider pinching effect , How can I model such models with acceptable accuracy ?
September 15, 2022 at 4:53 pm
abdalla
SubscriberI think that Solid 65 only can get the Pinching effect with high accuarcy because it contains the shear reduction feature.
Viewing 6 reply threads
- The topic ‘Can Ansys Workbench consider the PINCHING effect during modeling concrete shear wall under CYCLIC ?’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
1494
1386
1209
