Anybody knows good tutorial on installing visual studio for Fluent UDF compiling
    • yfeng4
      Dear All,nI want to ask if anybody knows a good tutorial on installing visual studio for Fluent UDF compiling. For example which version of the VS, and any additional steps need to be taken to make it work? nThank you very much.l n
    • YasserSelima
      You don't have to. The built in compiler in Fluent 2019 and later can compile your UDF. Write the UDF in a text editor and save it with extension .c in the same directory with fluent case file. nWhen compiling, check the box, use built in compiler before pressing buildn
    • yfeng4
      Thank you so much for your help! n
    • YasserSelima
      You are welcome!n
  • The topic ‘Anybody knows good tutorial on installing visual studio for Fluent UDF compiling’ is closed to new replies.
