solution combination
    • happykiran
      Can I use solution combination as a result of static structural and transient structural? please refer to the attached image
    • danielshaw
      Yes, you can use Solution Combination with the Mechanical Fatigue Tool, but it is only applicable between 2 results sets. The FT cannot be used to calculate the fatigue damage caused by more than 2 result sets.n
    • ErKo
      closed post
  • The topic ‘solution combination’ is closed to new replies.
