February 20, 2021 at 7:32 pm
KORAY2255
SubscriberI am facing surface mesh generation error with complex geometries when I try to add local face size or BOI with watertight geometry in Fluent Meshing? I can easily perform meshing these geometries without any local mesh size. Is there a way to overcome this issue?n -
February 22, 2021 at 4:41 am
Keyur Kanade
Ansys EmployeePlease make sure that you have defined correct sizing. You can measure distance between two positions or nodes in Fluent Meshing. Once you measure the distance, make sure that you have sufficient sizing defined for local sizing control. nYou can check sizing video on Ansys meshing. The definition of sizing function is similar in Fluent Meshing. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
- The topic ‘Fluent Meshing surface mesh generation problem?’ is closed to new replies.
Ansys Innovation Space
1333
1168
1090
1014
