February 18, 2021 at 6:07 pm
vinay91
SubscriberHello, I believe this should be someplace fairly obvious but I am unable to find it - is there an option to change the font size across all panels on the GUI on Electronic Desktop?n -
February 19, 2021 at 1:43 pm
VivekKamble
Ansys EmployeenMay I know the need for changing the font size? Have you changed your Monitor resolution or using a 4K display? nPlease let us know.nRegards,nViveknn -
February 19, 2021 at 3:02 pm
vinay91
SubscriberI dont believe there is a resolution issue. The display is not 4k. I am used to larger font sizes on other EDA software and would prefer the same on HFSS.nn -
February 22, 2021 at 1:09 am
AndyJP
SubscriberAnsys HFSS/Maxwell was never designed for modern PCs. It was not updated for 13 years at all, but generally the same UI as in the first windows release was kept till ver 2019.nNow they started using TTF fonts and Windows10 TTF scale.nHowever, the report engine is the same as 13 years ago, and you have to use a loupe to read labels there on 4K displays. I hope it will be fixed in ver 2021. But honestly, the whole report plotting engine needs revamping. Particularly the Smiths chart is horrible.n
- The topic ‘Changing font size across the GUI’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1241
1118
1015
