February 3, 2021 at 6:14 pm
Abubakar
SubscriberHi Kalyan Sir, nSir, I ran a steady simulation on the exhaust manifold with coupled algorithms, and the residual and results which I was getting were not appropriate I mean the residual was blowing for your reference I attached the snap so, but when I simulated with the SIMPLE algorithm by keeping other parameters same I got appropriate results.nSo, sir may I know what was the reason for residual was blowing? And How he gave correct results for the same conditions when ran with a SIMPLE algorithm. Thanks in advance.nnThank you,nAbu Bakar khan n
n
February 8, 2021 at 2:49 pm
System_delete
SubscriberThis discussion was created from comments split from: 4 Equations and 13 Unknowns. -
February 8, 2021 at 2:55 pm
Karthik Remella
AdministratornIf you wish to ask a new question, please create a new post for this. This would provide a better visibility to your question.nIt is possible that some problems converge with seggregated solvers better than on a Coupled. This is because of the differences between the two solvers - more importantly, how they solve the questions. Please read this page to understand the difference (Fluent Theory Guide). nWithout much knowledge of the problem you are attempting to solve, it might be difficult to answer this in specific terms.nThank you.nKarthiknn -
February 9, 2021 at 5:13 pm
Abubakar
SubscriberHi Karthik sir,nI am sorry for creating the confusion from next time whenever I want to ask a question I will make a new thread.nYes, I will go through the article and thank ??you so much for clearing my doubtsnnThank you,nAbu Bakar khann -
February 9, 2021 at 5:15 pm
Karthik Remella
AdministratorNo worries. Good luck!nKarthikn -
March 8, 2021 at 5:58 am
Abubakar
SubscriberHi Sir, nAbove link is not working for me Can you please tell me the section number for the same?nThank you,nAbubakar khan n -
March 8, 2021 at 7:49 am
Amine Ben Hadj Ali
Ansys EmployeeCan you add some more information about your case like boundary conditions, mesh quality and models used? n -
March 8, 2021 at 1:30 pm
YasserSelima
SubscribernHave a look at this topic to know how to open ansys help links.n/forum/discussion/22563/using-help-with-links#latestn -
March 8, 2021 at 1:34 pm
Karthik Remella
AdministratorHello,nThe section number is 28.1.1: Pressure based solvers.nIf you are attempting to open these Ansys Help links, please follow the instructions here.nHello,nThe section number is 28.1.1: Pressure based solvers.nIf you are attempting to open these Ansys Help links, please follow the instructions here.nKarthikn -
March 8, 2021 at 3:18 pm
Abubakar
SubscriberThank you sirnn
Viewing 9 reply threads
- The topic ‘Residuals Diverging’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
- Is it able to solve turbomachinery using density-based solver in Fluent?
- Two-way FSI simulation
- Ensight Force_per_unit area_EV
- Question about generating Porous Jumps
- The result in FLUENT differs from CFD Post
1494
1386
1209
