Electronics
Electronics
Incorrect current conduction in 3D simulation
    • uirgochen
      I'm simulating an ironless linear motor in 3D model,
      I found current flow from one coil to neighboring coil via contacted face,
      It's not correct in realistic operation.
      Even I set a little gap between them, it still happened.
      The current flow should be restricted inside coil solid.
      How to fix it? To avoid current flowing via the contacted face?
      Thanks,
      Vincent
    • icellb1
      Hi, nYou may try assigning an insulating boundary to the coils. Select the coil, right mouse click-->assign boundary-->insulating.n
    • uirgochen
      It works, nthanks a lot,nn
  • The topic ‘Incorrect current conduction in 3D simulation’ is closed to new replies.
