Preprocessing
Preprocessing
How to access the SpaceClaim script from the parameter window in Workbench
    • ArisvHouten
      Hello All,
      I have made a SpaceClaim python script which creates the geometry perfectly and I've assigned some parameters to it. These I want to do a parametric study over. But if I change these parameters from the parameters window in Workbench the Geometry Creation script does not run. Only when I open SC and do it myself, how can I automate this?
      As I have to do this for almost 200 designs...
    • RK
      Hello, nAre you seeing parameters in the geometry tab? nn
  • The topic ‘How to access the SpaceClaim script from the parameter window in Workbench’ is closed to new replies.
