February 3, 2021 at 6:15 am
cheolmae
SubscribernHellonMany time, I need particle analysis but Ansys Fluent does not work particle history export without separated file. If I check the separate file option then it is fine but too slow saving and need a lot of storage.nAnd I read almost every release note and limitation note but I cannot find any clue...nPlease let me know how can it works. Is it still bug? or just I don't know?n -
February 3, 2021 at 6:33 am
DrAmine
Ansys EmployeeWhat do you mean with separated files? You want only the particle export without the relates encas file?n -
February 3, 2021 at 6:37 am
cheolmae
In transient case, ensight file is separated each time step when you check the option Separate Files for Each Time Step. I don't want to separated files. But Fluent does not work unchecked state.n
February 3, 2021 at 6:51 am
DrAmine
Ansys EmployeeThat option should be the same as the automatic export of EnSight during calculation. So Unchecking should be consistent.You wrote this is not working:which version you are using? Can you reproduce on simple file?n -
February 3, 2021 at 7:10 am
cheolmae
SubscriberI already try that same option. That is just sample.nI try on 17.0/18.2/2019 R3nIf I uncheck on solution & particle history export window then fluent makes error and print this comment(2019 R3)Error at host:Â nFailed to open temporary file for sorting. -
February 3, 2021 at 9:14 am
DrAmine
Ansys EmployeeTesting the option and running as it should in 21R1.n -
February 4, 2021 at 12:51 am
cheolmae
SubscriberTesting the option and running as it should in 21R1./forum/discussion/comment/105412#Comment_105412
nnToday I try on 2021R1 and it worked!nThank you.nn
nBut I find a bug. If you set a particle history export option and again you open particle history window then looks like a reset.nCheck this out.n
February 4, 2021 at 1:28 am
cheolmae
And... um...Actually I use a trick about avoid saving *.vel file each time.nMethod is this.n※ In my cases, particle is very small about 0.3μm, so I don't calculate a flow and turbulence when particle tracking.nnSolution export interval set more then total particle iteration.nParticle history export set with checking separate file for each time.nI can get separated particle history ensight result files without *.vel saving for each time.nnAnsys 2021R1 is worked when set same interval between Solution export and Particle history export.nBut if I set a Solution export interval more then total particle iteration make error window like this below picture.n
nI hope check this also. nI hope *.vel saving interval can control.nBut by then I have to use this method.. n
February 4, 2021 at 10:34 am
DrAmine
Ansys EmployeeLocal Support will get in touch with you. Thanks!n -
February 4, 2021 at 10:39 am
DrAmine
Ansys EmployeeRegarding the setting get reset: I will take care here. I recommend here to write a message to support@ansys.com but as I said the local team will get in touch with you!n
Viewing 9 reply threads
- The topic ‘I want to know how can I get particle history data as Ensight without separated file’ is closed to new replies.
1330
1102
